1. Amazon.se har öppnat: Amazon SE | Fyndtips
  2. Registrera ett konto och bli del av Sveriges förmodligen trevligaste och mest hjälpsamma community.
  4. Apple-nyheter: 12 Pro Max | 12 Pro | 12 | 12 Mini
Guide: AutoRoot for GT-I9506 Running 4.4.2 Original
Diskussion i 'Galaxy S4 - ROM-filer och utveckling' startad av ZiMMeN, 14 sept 2014.
  1. ZiMMeN
    ZiMMeN Adult Droid Medlem
    29 dec 2010
    AutoRoot for GT-I9506 Running 4.4.2 Original.
    WARNING: The below operation WILL trigger the KNOW WARRANTY bit!!
    NOTE: This AutoRoot is ONLY for people having the GT-I9506 - European version, running stock 4.4.2 release version XXUCNG3.
    Flashing instructions:
    Download the Zip file below and unpack using 7-Zip.
    https://docs.google.com/file/d/0B6he3hscczvdTUhqSDk0ZDNMdzg/edit
    Go to the directory where you placed unpacked the Zip file.
    This archive contains Odin v3.07 set up for you. Start this Odin and click PDA, now select the SGS4+_AutoRoot.tar.md5 file.
    After a few seconds Odin has verified the md5 sum and is ready to flash.
    Put phone in download mode...etc etc...same as we always do.
    Just as a precaution: Check that only Auto Reboot and F-Reset Time is marked.
    Now press Start and the magic will happen.
    Phone will now flash and then reboot into a special Chainfire recovery.
    WAIT for the magic to happen.
    After this, phone will reboot as normal and you will end up at your normal system...now rooted.
    You can now disconnect the phone from your computer.
    Now find and start SuperSU, it will first ask you if you want to disable KNOX. Answer yes and wait.
    If SuperSU has not responded in about a minute, press and hold HOME button, Clear memory; press left hand icon and then select RAM, select Clear memory and confirm.
    Return to SuperSU and start it up again.
    Denna guid är skriven av DeHAWK på xda.
    Länkar den bara vidare så vi slipper söka så mkt :D
    osvanberg gillar detta.
  2. monsterapparat
    monsterapparat Baby Droid Medlem
    11 aug 2013
    Någon som har testat? :)
    Behöver man även flasha CSC-filen?
    Har nu KNOX warranty void 0x0 - behöver jag bry mej om något utöver förlorad garanti då KNOX triggas till 0x1?
    Jag tänker att det är ändå en gammal lur, dock oanvänd, men jag vill inte ha reklam i telefonen och önskar således köra adaway vilket kräver root.
    Dessutom upphör garantin att gälla ändå på hela telefonen så fort det är någon yttre åverkan på skärmen, så det känns inte som att man har så mycket att förlora på om KNOX skulle vara 0x1 :)
  3. erik7191
    erik7191 Infant Droid Medlem
    6 jan 2014
    Vad gör man om man har XXUCNF3 och inte XXUCNG3? Spelar det ens någon roll?
  4. SweAthlon
    SweAthlon Infant Droid Medlem
    10 jun 2015
    Samsung Galaxy S4+
    Samsung Galaxy S4+
    Apex Launcher Pro v3.01
    Samma fråga som erik7191..
