Ice Cream Sandwich - WIP [2011-12-07]
Diskussion i 'ZTE' startad av kallt_kaffe, 1 dec 2011.
  1. kallt_kaffe
    2 aug 2010
    Xiaomi Mi Note 10
    Xiaomi Mi Note 10
    First of all. Make sure you do a wipe. Also first boot takes really long time.
  2. Hallberg84
    Hallberg84 Teen Droid Medlem
    29 apr 2011
    Firat boot for me took about one smoke and a visit on The toilet, means a real long time
    Sent from my V9 using Tapatalk
  3. DaKKs
    DaKKs Adult Droid Medlem
    6 apr 2011
    Mine is still booting after 20 bloody minutes. And i've restored to telia 2.2 twice already. Same thing. Left it to boot for hours before i restored for the first time, didn't do shite. It just wont go past the boot anim. Bugger all, back to CM7, i guess.
    EDIT: Got it running now.
  4. bobbe21
    bobbe21 Infant Droid Medlem
    2 jun 2011
    Några tips på att ta sig till FTM? min dyker in i clockwork.
    Det var på tok för länge sedan jag pillade med detta :)
  5. Wallandroid
    Wallandroid Teen Droid Medlem
    15 apr 2010
    Samsung Galaxy S10E
    Samsung Galaxy S10E
    Det funkar i clockwork också.
    bobbe21 gillar detta.
  6. grantacraig
    grantacraig Infant Droid Medlem
    15 jul 2011
    Hi Dakks
    You say you have it running now. Did you do anything or just wait. I have tried waiting for over an hour and still in the animation screen
    Marvin
  7. swanden
    swanden Adult Droid Medlem
    5 feb 2011
    Någon chans att denna kommer till ZTE Blade? Det är väl i princip samma hårdvara.
  8. DaKKs
    6 apr 2011
    Wipe data and cache before you flash ICS. Otherwise it'll be stuck on anim. At least, that fixed it for me. I dunno what i did to bugger it up so spectacularly but after i realized that i have to wipe before, it worked like a charm.
    Cheers, mate.
  9. lefffen1
    lefffen1 Kid Droid Medlem
    4 sept 2010
    Tycker det flyter på rätt bra! Dock lyckas jag inte få in gapps. Har testat flera gånger.. Någon som lyckas få det att funka?
  10. DaKKs
    6 apr 2011
    Nope, ingen gapps för mig heller.
  11. Nickee
    Nickee Teen Droid Medlem
    28 apr 2010
    Huawei P20 Pro
    Huawei P20 Pro
    Samma här, har original 2.2, partitionering.
  12. Oxygen
    Oxygen Youth Droid Medlem
    17 jun 2010
  13. lefffen1
    4 sept 2010
    Funkade inte tyvärr. tack iaf
  14. lefffen1
    4 sept 2010
    Fick gapps att fungera nu! inte säker på vad som gjorde de, testa massa saker me adb innan men antagligen va de "fix permissions" i clockwork som fixa de.
  15. Jerker
    Jerker Kid Droid Medlem
    25 feb 2010
  16. Nickee
    28 apr 2010
    Huawei P20 Pro
    Huawei P20 Pro
    Jag testa och uppgraderade clockwork så nu funkade det.
    Flasha den Jerker kom med. :)
  17. bohdans
    bohdans Baby Droid Medlem
    31 aug 2011
    Hi,
    Just a note to all, after "waiting" 2 hours for the first boot I realized that the second version is ONLY an update.
    After flashing the first one, THEN the update the first boot took around 20mins.
    Also Gapps works fine for me.
  18. bjoli
    24 jun 2009
    Finns det något enkelt sätt att se vad jag har för partitionslayout idag? Tror nämligen att jag aldrig har bytt.
  19. gosa
    gosa Adult Droid Medlem
    7 jul 2010
    Quick system info är en grym liten app för att hålla rätt på utrymmet.
    Kommer tyvärr inte ihåg några siffror på rak arm, men kör du den och ser att du har massor av plats ledigt på /system (med cm7) så kör du original... har du bara mellan 5-10mb ledigt på /system så kör du moddad layout.
    bjoli gillar detta.
  20. kallt_kaffe
    2 aug 2010
    Xiaomi Mi Note 10
    Xiaomi Mi Note 10
    Meny -> Inställningar -> Lagring -> Intern lagring. Har du runt 300Mb intern lagring :)data partitionen) så kör du en "custom" partitionering. Kommer inte ihåg på rak arm hur stor data-partition original layouten har men om jag inte minns fel så är den under 200Mb.
    bjoli gillar detta.
