Hej.
Ville bara dela med mig denna mod för MTK versionen av Redmi Note 4x MTK Helio X20. Ska fungera på andra också.
Har installerat men ej testat om det blev något bättre då jag ska ladda telefonen fullt först för att sen testa skillnaden på batteritiden.
OBS! Detta är någon annan som har gjort modden inte jag själv OBS!
Introduction
Have you ever wonder why overnight 15-20% battery drains. Now no worries,
Our phones are more powerful than ever. With lusciously crisp screens, GPS navigation, and quad core power, our phones can render a pixel better than ever. This naturally comes at a cost, battery life. Many people have resorted to carrying extra battery packs around, like the Lepow U-Stone or the RavPower RD-WD01. However, there is a way to control your battery from your phone.
Android: Deep Sleep aims to keep your battery from draining overnight by forcing the phone into a deeper sleep, Instead of leaving it up to the OS or putting the phone into a permanent sleep until you wake it.
Works on Any ROM and Any kernel. Even Stock ROM and Stock Kernel. Just you need custom recovery.
Instructions
> Download Zip
> Place it in Internal Storage
> Flash it through Custom recovery (Recommended TWRP)
> Clear Cache Partition (Important)
> Reboot System.
> Done
Huge battery saving coming on the way
Note : It will not work while charging
LINK!
https://drive.google.com/open?id=0B0mRC0Z3somRZGdBa19yakg3ZjQ
LINK!
