Tips: Ny firmware för Note II LTE (4.1.2)
Diskussion i 'Galaxy Note 2 LTE' startad av DavidW, 11 dec 2012.
  1. DavidW
    DavidW Teen Droid Medlem
    13 okt 2010
    International Samsung Galaxy Note 2 and Note 2 LTE now getting Android 4.1.2 update
    http://www.androidauthority.com/int...ote-2-note-2-lte-android-4-1-2-update-138213/
    The three-month old Galaxy Note 2 has been Samsung’s first device to run Android 4.1, so it was only natural to expect it to be the first to get 4.2 as well. And while that’s still in the cards, it seems that we’re all going to have to wait for a bit longer because the GNote 2 is being upgraded right now, but only to 4.1.2.
    This is not a major shocker however, because the maintenance update for the second-gen phablet got leaked just last week, previewing the official bump that’s going on as we speak. We’ve also seen a couple of Galaxy S3 models getting the same 4.1.2 upgrade, so it was all building up to this.
    For the time being, we have only been informed about two specific GNote 2 versions getting Android 4.1.2, but it’s obvious the rollout will increase in intensity very soon – at least across Europe. Poland is once again the icebreaker, with the Note 2 on carrier Play (model number GT-N7100) getting the update a few hours ago.
    Sweden is number two on the list, but the phablet upgraded there is an LTE-enabled version (model number GT-N7105), so you can say the Swedes are road-openers as well. Both countries are getting the same software package though, with a JZO54K build number and a November 26 build date.
    The upgrade’s changelog is pretty massive, but at a first glance there aren’t as many new features to get excited about as on the Galaxy S3. It’s no wonder though, because the piece de resistance on the S3 was definitely Multi-View, a feature that the Note 2 packed for a while. Here are some of the tweaks, though we’re not sure the list is an official and complete one:
    New additions in Notification Toggles
    Notification Panel can now be customized
    Brightness Slider in Notification Panel can be disabled
    Multi-View can be disabled
    Smoother browser
    Status Bar has been changed from Grey to Black
    Continues Input in Samsung Keyboard
    New Ink Effect on Lockscreen
    New Group Cast app
    As usual, expect the update to be available both OTA (over-the-air) and through Samsung Kies and to generally hit unlocked phones before carrier branded versions. As for North American GNote 2s, those should themselves get the new software package “soon”, though if we were to speculate we would say you’re faced with at least one more week of waiting.
    Now, who’s got the upgrade already, where and how? Are there any new features or tweaks you’d like to add to the above list?
    Related Posts
    Galaxy Note 2 LTE Android 4.1.2 Jelly Bean update gets leaked
    Rogers Jelly Bean update for Samsung Galaxy S3 and Galaxy Note arriving soon
    It’s here, folks: Samsung Galaxy Note Android 4 ICS update now rolling out in Europe
    Sent by gReader Pro
  2. Cylon
    Cylon Adult Droid Medlem
    19 aug 2009
  3. infinite222
    infinite222 Youth Droid Medlem
    21 feb 2011
  4. Cylon
    19 aug 2009
    Visst, men så svårt är det inte och skriva:
    'Länk här'
    Skickat från min GT-N7105 via Tapatalk 2
  5. S-Droid
    27 jul 2010
  6. J.K Nilsson
    J.K Nilsson Kid Droid Medlem
    9 nov 2009
    Men vad trevligt. Den tankas hem nu.
    J.K Nilsson
  7. Cylon
    19 aug 2009
    Flashat,
    Lite snabbare, och bättre mottagning, men annars har jag inte märkt någon större skillnad.
  8. S-Droid
    27 jul 2010
    Du kan ändra om lite i notifikationsbaren
    Group cast app, bläckeffekt på låsskärmen bla
  9. AKERSKUUUG
    AKERSKUUUG Adult Droid Hedersmedlem
    14 dec 2010
    Samsung Galaxy S6
    Samsung Galaxy S6
    HTC One M8
    Apple iPhone 6 Plus
    Google Nexus 7 (2013)
    Bläckeffekten var lite trevlig. :)
  10. S-Droid
    27 jul 2010
    Visst funkar den bara med pennan?
  11. S-Droid
    27 jul 2010
    Nu kan man använda vol knapparna till antingen zoom eller ta kort
  12. J.K Nilsson
    9 nov 2009
    Det verkar inte bara vara jag som laddar TLA-filen ifrån Hotfile ^^
    J.K Nilsson
  13. viwa
    viwa Youth Droid Medlem
    23 maj 2010
    Någon med tele2 som provat den?
  14. S-Droid
    27 jul 2010
    går alltid segt därifrån
    Hur mycke har du kvar?
  15. Pliind
    Pliind Professional Droid Medlem
    4 jun 2010
    iPhone 14 Pro Max
    iPhone 14 Pro Max
    iPad Pro
    Apple Watch 7 Steel
    Antar att det bara är att köra odin och lägga den nerladdade filen under PDA.
    Frågan är om root och mina moddningar försvinner med uppdateringen?
  16. S-Droid
    27 jul 2010
    Det gör dom, flasha i mobile odin så slipper du roota om den
    Här finns den en annan snabbare länk
    http://www.multiupload.nl/KBDJHU7W9X
    Pliind gillar detta.
  17. Pliind
    4 jun 2010
    iPhone 14 Pro Max
    iPhone 14 Pro Max
    iPad Pro
    Apple Watch 7 Steel
    Länken tackar vi för! (Edit: men länken du gav nu är inte samma som skulle funka med Telia)(edit2: den var dessutom för n7100)
    Hmm så flashar jag med Odin så bibehålls min root alltså?
  18. S-Droid
    27 jul 2010
    Mobile odin ja och inte vanliga odin, everroot ska vara ikryssat så kolla det innan du flashar
  19. Pliind
    4 jun 2010
    iPhone 14 Pro Max
    iPhone 14 Pro Max
    iPad Pro
    Apple Watch 7 Steel
    Aight, nu hann du svara för snabbt här :P
    Länken du gav var till N7100
  20. Cylon
    19 aug 2009
    Root har inte försvunnit för mig iallafall,
    Men kan inte säga något om moddningar.
