  1. mickej79
    mickej79 Senior Droid Medlem
    18 jun 2009
    Samsung galaxy s22 ultra
    Hur blir man root i denna rom?
  2. Terror
    Terror Teen Droid Medlem
    24 maj 2011
    Changelog Omega Series v14: - Not released yet
    Based on firmware XWLPF Android 4.03 (Date: 18/05/2012)
    New:
    Modem: XXLPX
    Kernel: Kernel CF-Root XWLPF
    Sounds form SG3
    Updated:
    Omega's csc: XXLP7 (multi 57)
    Google Maps v6.8.0
    Apex Launcher v1.2.1
    Nova Launcher v1.1.4 (Only to ICS Theme)
    NoLed v5.2.3
    Airdroid v1.0.6
    Google Translate v2.4
    hosts
    Removed:
    Lidroid mod
    Mods:
    JKay Deluxe Mod v14
    + 18 scrollable quick panel toggles incl:
    'Do not disturb' quick settings button (the notification toggle from tablets)
    'Screen on' quick settings button (temporary 3 mins of screen on)
    'Auto brightness' quick settings button (long press to adjust brightness and auto-brightness using a slider)
    'Mobile data', 'Airplane mode', 'Vibrate' toggle, Wi-Fi hotspot, Sync, Flashlight and the 4 reboot toggles
    Long press on these toggles to go to settings!
    + Original ICS lockscreen
    + Live wallpaper support on lockscreen
    + 6 bars for GSM signal
    + Custom date format on status bar
    + Next Alarm Info on drag bar
    + Transparent statusbar on lockscreen
    + Redesigned Samsungs WiFi icons as I did not like the ICS look from Samsung!
    + Separate Wifi In/out arrows
    + Removed leading zero to hour on status bar (to changed '09:00' to '9:00')
    + Semi transparent connection icons
    + 'Fast screen off' to turn the screen of faster!
    + Toggle flashlight by long pressing Home button on any lockscreen!
    + Toggle sound on/off using volume buttons on any lock screen
    + Disabled 'Battery full' notification
    + Disabled 'Bluetooth' notification
    + Long press volume buttons to skip track (when music is playing and screen is off, and note: this also works when you have set lockscreen to None!)
    + Connection icons are green when fully connected to google servers
    + Battery with percent (100 steps plus 100 steps charging)
    + Added 'Reboot to Recovery' and 'Reboot to Download' to the phone dialog panel
    + Enabled fast double click (350ms instead of 500ms)
    + Enabled CRT off effect when screen off
    JKay Deluxe Settings is not included, get it from here
    Theme:
    Many Icon changes in all roms - work in progress, more icons in next versions
    Notification text themed in Black Blue and ICS
    Credits to siberian tiger his help.
    Rom is no Full Wipe
  3. ante_ante
    ante_ante Adult Droid Medlem
    8 apr 2010
    Galaxy S10+
    Galaxy S10+
    Va ska dom gå tillbaka till 4.0.3 nu?
  4. Terror
    24 maj 2011
    4.0.3 har jag på V13 också
    V14 släppt
  5. drkrupp
    drkrupp Adult Droid Medlem
    6 sept 2010
    Behöver man köpa JKay-appen nu för att ändra vilka knappar som ska finnas i rullgardinen?
  6. Terror
    24 maj 2011
    jag tror de ,, JKay är väl inbyggt in denna lr har ja fel
  7. moparlinke
    27 jul 2009
    Flashade in denna ikväll och fasen vad jag gillar den.
    Nu finns flytet i webbläsaren där igen.
    Överhuvudtaget flyter den grymt fint.
    Men synd att den ska vara piiiiip full av junk.
    Dock fixat rätt snabbt men hade hellre sett en version med bara det nödvändigaste.
    Ska bli kul att se hur den mycket stret den slukar i sig.
    Nån kernel som ska va extra bra ?
    Så länge sen jag flashade att jag inte ens kom ihåg vad jag hade sist hehe
  8. Terror
    24 maj 2011
    kör med senaste siyah kerneln
  9. drkrupp
    6 sept 2010
    Denna senaste versionen flyter mycket bättre än förra för mig. Bättre batteritid också.
  10. TippZ
    TippZ Bannlyst Bannlyst
    26 feb 2012
    borde kanske uppdatera tråden... ni får ursäkta så mycket!
    sådär!
  11. Terror
    24 maj 2011
    Changelog Omega Series v15
    Based on firmware XWLPG Android 4.03 (Date: 24/05/2012)
    New:
    Kernel: CF-Root XWLPG
    Updated:
    Airdroid v1.0.7
    Google Translate v2.4.1
    Dropbox v2.1.4
    Google Plus v2.6.1.30454518
    Google Maps v6.8.1
    Street View v1.8.0.1
    hosts
    Theme:
    Stock: added two battery mods
    Rom is no Full Wipe
    Omega Series v15
  12. laizita
    laizita Kid Droid Medlem
    25 okt 2009
    Någon som vet hur man kan ta en skärmdump i denna rom? Power + Home fungerar inte alls, har även tittat i hans kitchen-avdelning utan framgång.
    någon?
    *edit*
    bör tillägga att jag sitter med v13.
    testat allt känns det som. :/
  13. drkrupp
    6 sept 2010
    Power+Home funkar för mig, men du måste hålla in knapparna i 2 sekunder.
  14. laizita
    25 okt 2009
    Hmm, fungerar inte här.. :/
    Får väl ta och köra in v15.. ville inte göra det från början då jag är extremt nöjd med v13.
  15. drkrupp
    6 sept 2010
    Jag var missnöjd med v13, men v14 funkar kanon. Har inte provat 15.
  16. Terror
    24 maj 2011
    volym ner + power
  17. zappa79
    zappa79 Adult Droid Medlem
    23 aug 2010
    Vart får man tag på jkay deluxe?
    Verkar inte finnas på Google play!
  18. Terror
    24 maj 2011
  19. magnea
    magnea Teen Droid Medlem
    23 dec 2010
  20. zappa79
    23 aug 2010
