Samsung Galaxy GT-N7000 wifi problems after upgrading to android 4.2.1
Diskussion i 'International forum' startad av Pinoyviking, 17 nov 2016.
  1. Pinoyviking
    Pinoyviking Infant Droid Medlem
    15 okt 2016
    Hi all,
    I can not get the wifi to work on my Samsung Galaxy (GT-N7000) after upgrading the software to Android version 4.2.1.
    When i press the wifi button, it will just light for about 1 second, then that "green" wifi gradually turns back to grey (deactivated mode).
    Will another upgrade to Android 4.3 work with this phone?
    thanks in advance
    R3b0rn gillar detta.
  2. R3b0rn
    11 apr 2010
    Hi!
    Usually when these kinds of bugs happen its because of some residue left by the firmware you upgraded from.
    The easiest way to try to fix this is by making a full wipe and factory reset.
    If this doesn't fix it, the next step is to download a stock samsung update file and use Odin. Odin is an application that can flash your firmware completely clean.
    If you give me a minute I shall point you in the right direction.
    Pinoyviking gillar detta.
  3. Rospigg
    11 aug 2010
    Galaxy S22
    Galaxy S22
    Hi!
    One idea is to do a factory reset on the phone.
    After an update it is wise to do a reset on the phone, especially on the older versions of Android.
    There are no further updates to your phone. But there are several unofficial ROMs available that are bulit on 4.4.4 KitKat. But its not the easiest thing to do!
  4. Pinoyviking
    15 okt 2016
    [QUOTE = "R3b0rn, mail: 1983694, member: 6038"] Hi!
    Usually When These kinds of bugs happen ITS Because of some residue left by the firmware you upgraded from.
    The Easiest way to try to fix this is by making a complete wipe and factory reset.
    If this does not fix it, the next step is to download a stock Samsung Update File and Use Odin. Odin is an applicationthat can flash your firmware completely clean.
    If you give me a minute I Shall point you in the right direction. [/ QUOTE]
    Sure. I would appreciate any help!
  5. Pinoyviking
    15 okt 2016
    I did the first step a couple of times already but to no avail...
  6. Pinoyviking
    15 okt 2016
    Thanks. I did the factory reset several times.
    Rospigg och R3b0rn gillar detta.
  7. R3b0rn
    11 apr 2010
    Do you have any way to check your CSC region code?
    That would help out.
  8. Pinoyviking
    15 okt 2016
    I don't know how to do that...
  9. R3b0rn
    11 apr 2010
    Download an app called: Phone INFO *samsung*
    And swipe to the csc section.
  10. Pinoyviking
    15 okt 2016
    Hang on, i'm on it...
