Diskussion: Sennheiser MOMENTUM True Wireless 2
Diskussion i 'Hörlurar' startad av Ascended, 15 mar 2020.
  1. Ascended
    30 jun 2012
    Samsung Galaxy Z Fold 5
    Unrivalled stereo sound
    From classical to contemporary, every music genre is enhanced by the bespoke 7 mm dynamic drivers of the new MOMENTUM True Wireless 2 earbuds thanks to its deep bass, natural mids and clear, detailed treble. Plus, you can now tailor your listening experience with built-in equalizers and enjoy amazing sound quality on your terms.
    Your sound. Your focus.
    Concentrate on the right thing at the right time with the MOMENTUM True Wireless 2.
    Switch off your surroundings and dive into that impactful song, important episode or impromptu call with the new Active Noise Cancellation feature. Working in tandem with the earbuds’ excellent passive noise isolation, you now get to enjoy incredible high-fidelity sound even in noisy environments.
    Then seamlessly bring your focus back and listen to what’s around you thanks to Transparent Hearing.
    Comfortable all-day listening
    Up to 28 hours play time
    Experience uninterrupted play time with the new
    7-hour battery life that can be extended up to 28 hours
    with the charging case.
    Improved ergonomic design
    In the mood for a movie marathon? With its ergonomic
    design, you can experience unbeatable sound in
    unbelievable comfort.
    Intuitive to your needs
    Customizable controls
    Control your volume, music and calls with customisable touchpad technology built into both earbuds.
    Voice Assistant support
    Easily activate Google Assistant and Apple Siri at the touch of a button and hear their replies loud and clear.
    Smart pause
    Never miss a second of your favorite song. Smart Pause automatically stops when your earbuds are removed and seamlessly resumes when you put them back.
    Carefully designed. Confidently delivered.
    IPX4 rated
    Enjoy outstanding audio experience no matter where you are with IPX4 splash resistant design.
    Craftsmanship
    Exquisite craftsmanship, with a beautiful design now available in an all new white and grey color scheme as well as classic black.
    Sennheiser MOMENTUM True Wireless 2 - - Earbuds that put sound first
    Release date: April 2020
  2. Ascended
    30 jun 2012
    Jag var otroligt nöjd med den första generationen, dock hade den 2 stora problem, battery drain och den dåliga batteritiden överlag. Detta ser Sennheiser ut att äntligen ha löst med Gen 2.
    Utöver det så har dom nya följande förbättringar:
    -ANC
    -Mindre (bättre passform)
    -Customizable controls
    med mera.
    Jag förhandsbokade dom direkt! Förväntas släppas i början på April :)
  3. psp123
    Mycket intressant pga. förbättrad batteritid och ANC. Hoppas de levererar.
    bernard och Ascended gillar detta.
  4. Ascended
    30 jun 2012
    Ja, om alla påståenden från Sennheiser stämmer om dessa Gen 2 så är det nog dom första True Wireless som jag kommer bli riktigt nöjd över. Visst har dom inte allt, hade gärna sett ännu lite mer batteritid etc, men det är dom första som inte saknar något jag verkligen behöver.
    T ex Galaxy Buds saknar APTX vilket gör dom värdelösa med min PC.
    Uppskattar att man nu kan styra både kontrollerna och alla parkopplade enheter via appen :). Visst är det inte något riktigt multi point, men det bästa efter det iaf :)
  5. psp123
    Jag använder främst trådlösa lurar till podcasts och ljudböcker. Mycket nöjd med AirPods Pro förutom avsaknaden av volymkontroll. Bra med fler alternativ.
  6. Ascended
    30 jun 2012
  7. bernard
    Hur mycket sticker dessa ut från örat i jämförelse med Galaxy Buds tror ni?
    De verkar ju inte skriva ut yttermåtten för lurarna, bara för fodralet?
    Ascended och astrob0y gillar detta.
  8. Ascended
    30 jun 2012
    Definitivt mer än Galaxy Buds, har inga exakta mått dock. Personligen så störde jag mig inte på det när jag ägde Gen 1.
    Antar att det är priset man får betala för ljudkvaliten :)
  9. Ugga
    Ugga Senior Droid Medlem
    17 jun 2018
    Spännande! Jag har första generationen och är riktigt nöjd. Har ju andra over-ears(Mobius, P7W, Fidelio X1, H9 Gen3 mfl) om jag ska använda lurar längre perioder så för mig har jag inte riktigt stört mig på batteritiden och använder de ändå så pass ofta att drainet inte varit ett problem heller.
    Köpte mina för 1600kr från Sennheisers Outlet och måste säga att ljudet var över förväntan och anslutningen laggar/krånglar aldrig för mig.
    Ser fram emot tvåorna och det kan nog bli att testa dem senare i år. :)
  10. bernard
    Någon som springer med föregångarna, och har detta orsakat problem?
    Det står att de är IPX4-certade/splash proof, men det betyder inte riktigt samma sak som "sweat proof" (som en del lurar marknadsförs med).
  11. Ascended
    30 jun 2012
    Jag har inte hört att någon har det problemet på diverse Hifi communityn.
  12. bernard
    Ja, okej, då har du nog övertygat mig :) Jag avvaktar lite i väntan på ert omdöme vad gäller ljud och batteritid.
  13. Juturna
    Juturna Adult Droid Medlem
    12 jun 2016
    Vad tror folk om dessa versus Sony WF-1000XM3 och AirPods Pro? Vet inte riktigt vad jag ska prioritera. Kör iPhone i dagsläget och hade ett par Sony WF-1000XM3, där jag tappade fodralet och det var helt miserabelt för det gick inte att få ett nytt fodral för lägre kostnad än att köpa nya, så är lite missnöjd med hur Sony skötte det, men ljudet var grymt. Men fodralet är också så satans stort att det var en av anledningarna till att jag tappade det, den ville krypa ut ur fickan hela tiden, vilket resulterade i att jag inte märkte när det sen hände heller.
    Fick rätt ont i öronen av Sonys åtminstone i någon vecka eller två (sen började jag vänja mig vecka 3, sen tappade jag fodralet)
    Men samtidigt är Sonys ganska rejält mycket billigare vs dessa och AirPods Pro så...
    Kör på Galaxy Buds just nu men är inte helt nöjd med ljudet, det är stabilt och säkert relativt neutralt eftersom att dom förhåller sig till Harman-kurvan men lite väl mycket skrikig treble ibland, och överlag väldigt oengagerande ljud, och går ju inte att byta EQ på lurarna i någon app för iOS dessvärre.
    Ascended och bernard gillar detta.
  14. Ascended
    30 jun 2012
    Min högsta prio är ljudkvalité, därav hamnar valet på Sennheiser, både Galaxy Buds och Air Pods pro saknar APTX vilket är en deal breaker för mig då jag vill använda hörlurarna med min dator också.
    För mig går även Sony's bort pga saknad av någon IP-rating, extremt stort laddingsfodral och dess udda formfaktor.
    Momentum 2's ANC ska tydligen också vara väldigt imponerade om man ska tro diverse first impressions.
    Det ser dock ut som att du äger minst 1 IOS-produkt, då blir väl ändå Air Pods pro ett ganska bra alternativ också, men jag som kör 100% Android/Windows så är Air Pods Pro inget alternativ.
  15. Ascended
    30 jun 2012
  16. ruva
    ruva Senior Droid Medlem
    26 sept 2010
    Vimla (Se) och DNA (Fi)
    One Plus 6
    One Plus 6
    Nexus 6P
    iPhone SE
    Samsung Tab S2
    Jag springer med föregångarna men föredrar Airpod Proo då de känns mindre i öronen. STW har ju bättre ljud från Garmin klockan eller mobilen men regnar de så tar de kommandon från dropparna dvs man kan få ett ständigt "Volym Low" upprepande i öronen. Stänga av, ruska en stund hjälper.
    View: https://youtu.be/gBnEseFax74?t=11
  17. Juturna
    12 jun 2016
    Har någon införskaffat dessa än eller så och har någon liten review?
  18. bernard
  19. Ascended
    30 jun 2012
    Jag har ägt mina i ca 2 veckor (Komplett skickade dom riktigt tidigt av någon anledning), är extremt nöjd. Är du mest ute efter en riktigt bra ljudkvalité så finns det ingen konkurrens.
    Men värdesätter du andra egenskaper så som bra samtalskvalite eller riktigt bra batteritid så finns det andra alternativ. Det är inget fel på batteritiden, du får drygt 6.30h per laddning, men t ex Galaxy Buds har ca 10 h.
    Men som sagt, just när det kommer till ljudkvalité så är dom helt underbara, passformen är även god, de
    t finns en IP-rating, du kan själv modifiera touchkontrollerna och hearthrough läget funkar utmärkt.
    Är du villig att betala ett premiumpris för ett premiumljud? Då finns inte många alternativ förutom just Sennheiser MTW2 :)
  20. Ascended
    30 jun 2012
    Ska också tillägga att ANC inte förändrar ljudbilden på något sätt, vilket är väldigt positivt, använder dock inte ANC mycket då det påverkar batteritiden och att jag faktiskt har en såpass god passform/seal att det knappats behövs förutom vid "ovanliga" tillfällen t ex vid kraftigt vind eller vid flygresor.
    Vill också gärna påpeka att Bluetooth 5.2 lär förbättra True Wireless lurar på flera fronter, då en massa egenskaper kommer att standardiseras. T ex Left/Right independent connection (hjälper mot latency), low battery codec LC3 etc. Istället för att vara beroende av Qualcomm och dess licenser så blir det standard direkt via Bluetooth.
    Teknik utvecklas alltid, men just steget till BT 5.2 känns väldigt stort, så du kan absolut vänta en stund till innan du köper ett par dyra True Wireless likt dessa. Men vill du ha det bästa som finns just nu så är MTW2 ett utmärkt val.
