ZTE LIGHT V9 Android 2.2 upgrade from ZTE
Diskussion i 'ZTE' startad av Swedroidman, 17 mar 2011.
  1. Swedroidman
    Swedroidman Teen Droid Medlem
    10 nov 2010
    Realme GT Neo 2
    Realme GT Neo 2
    Global
    Skrivet av Sebastian404 på Modaco forumet, lägger ut det för er som inte är medlemmar där.
    1) download the two files from the first post
    2) unrar both files to a temporary directory
    3) install the Sales_MultiDL_MSM7227_V1.00.01 program
    4) download this PATCHED exe (thanks to mrradmir) and place it into the directory you installed MultiDL_MSM7227_V1.00.01
    5) run Sales_MultiDL_MSM7227_V1.00.01 program and at the bottom left point it at the location you unrared the larger file
    6) remove the usb cable and the battery from your device, wait 10 seconds, put it the battery back in.
    7) holding down VOL UP + VOL DOWN press the power button, you will see the power LED flash once
    8) now connect the USB cable to your PC
    9) using hardware manager find the port for your device and set it in Sales_MultiDL_MSM7227_V1.00.01's setting (read the DOC file for more info)
    10) at the bottom of the application under 'File Information' press SW Directory and browse to the 'V9_GENERICV1.0.0B03(offical)' directory
    11) in Action Mode tick the 'Backup NV' box and then Press 'Start All'
    12) you should find a file called 'Channel1.nvm' in the program directory, take a copy of that
    13) back in Action Mode tick the 'Download' box and Press 'Start All' again
    14) wait
    15) pray
    DiscoBoy, BuckNaked, OneZerOne och 2 andra gillar detta.
  2. MaXmeOliver
    26 mar 2010
    Nothing Phone 1 (12/256)
    Någon som har testat ovanstående?
  3. grief
    grief Senior Droid Medlem
    27 dec 2009
    Oneplus 3
    Oneplus 3
    Motorola Lumia 640 LTE
    SGS3
    Sony Z3 Tablet Compact 611
    iPad 2 3G
    Väntar på dig!
  4. DaKKs
    DaKKs Adult Droid Medlem
    6 apr 2011
    fan e det så att ingen vågar? då får man testa själv iaf. ska uppgradera so fort tableten kommer.
  5. Mr._E
    Mr._E Baby Droid Medlem
    31 aug 2009
    Uppdatera min nyligen anlända ZTE Light enligt Modacos instruktioner men med den patchade exe-filen istället för orginal (slapp allt klabb med license) å det funkade skitbra tills den hade installerat uppgraderingen!!!
    Så fort jag bootade om så kom jag tillbaks till FTM-bilden och kom inte runt det... :( Kastade mig över forumet hos Modaco och fick följande tips:
    Håll nere Volym Upp och starta enheten!! Nu kör jag 2.2. :)
  6. Jaevlar
    Jaevlar Youth Droid Medlem
    4 aug 2010
    Ni som vågat ta steget och pulat in 2.2-romen, hur upplever ni den jämfört med 2.1? Fungerar allt som det ska, dvs apps2sd, kamera, gps etc? :)
  7. Icey
    Icey Kid Droid Medlem
    13 apr 2010
    Flashat 3 light nu utan problem! För er som inte har gjort det, gör det! Så mycket bättre! Sen launcher pro på det så blir det en helt annan tab!
    widL gillar detta.
  8. TheEdge
    TheEdge Adult Droid Medlem
    15 dec 2010
    funkar market? svenska osv? flash? app2sd?
  9. Icey
    13 apr 2010
    Inte flash, men allt annat funkar fint!
  10. TheEdge
    15 dec 2010
    Ska man göra en backup innan om det skulle skita sig? Hur gör man det i såfall?
    Sent from my Desire HD using Tapatalk
  11. mammaspappa
    mammaspappa Infant Droid Medlem
    29 apr 2011
    Funkade! Tack! Dock var det lite läskigt att sätta igång den igen, men att hålla in volume up- och powerknappen under uppstart fungerade!
    Mkt snabbare nu! Tack igen!<3
  12. BalsbyMange
    BalsbyMange Youth Droid Medlem
    25 nov 2009
    Uppgraderade precis till 2.2, funkade kanon trots att jag gjorde en del saker i fel ordning. Hamnade i FTM läge efter uppgradering men de löstes med volume up och poer i 3 sek.
    Kan bara rekommendera att göra detta, mycket bättre flyt i lighten.
    Nu vidare till rootning o recovery
  13. TheEdge
    15 dec 2010
    Fan får detta fel!!
    Kolla in bilden!
    "The Version is not matching,can not use this software!"
    SORG
    Kanske man måste göra en återställning innan?
    Har ju en del skit installerat på den....launchers osv!
    Vad tror ni?
      Filstorlek:
      80,8 KB
      Visningar:
      180
  14. mightyman
    mightyman Infant Droid Medlem
    3 mar 2010
    Hade samma problem. Löste sig när jag startade Sales_MultiDL_MSM7227_patched från mappen där jag installerade orginal
    Mvh John
  15. TheEdge
    15 dec 2010
    Hade ni Super User i bockad?
    Jag hade det inte och nu när jag vill göra det så funkar det inte att bocka i!
  16. mightyman
    3 mar 2010
    Hade inte den i bockad
  17. TheEdge
    15 dec 2010
    nu jobbar den håll tummarna!
  18. TheEdge
    15 dec 2010
    Klart!!
    Håller på att testa.....kan ni dra ner den övre status raden?
    Funkar inte på min!
    EDIT: Funkar i liggande men inte i stående!
    Laddar nu hem Go Launcher EX
  19. TheEdge
    15 dec 2010
    det var bara en inställning!
    Fick det att funka nu!
    Är det bara jag som är här!?
  20. Swedroidman
    10 nov 2010
    Realme GT Neo 2
    Realme GT Neo 2
    Global
    Nice!! snart kommer alla Telia sålda vara flashade med 2.2 :D
