Defects:
- Screen flexes under touch pressure
- Screen corruption under touch pressure
- Screen corruption during usage, like a crazy re-sizing screen image
- Screen inner scratch
- Touch screen or Touch buttons response errors
- Imperfections to the coating and poly-carbonate finish
- Connectivity problems with SIM card/wifi etc
- Extreme overheating
Things not considered defects:
-Rattle when shaken around the camera area, this seems the case with most One X and most phones, doesn't affect functionality
- Flicker only in certain apps like the browser, youtube, a problem that needs update
- We know there is a problem with Tegra 3 drivers and awaiting updates
- Battery seems to have problem with firmware 1.26 to early to know battery defect, awaiting updates and batteries to calibrate
- All One X have one thing in common, heat so it's not a defect, it seems, probably some are hotter than others, might be related to Tegra3 driver issues
- Yellow spots on screen might not be a defect since iPhone 4 had the issue and they disappeared after a week of usage or so
- Yellow tint on the screen is caused by the lamination process, rooted ROMs might be able to re-calibrate later
Saxat från XDA.
