[KERNEL][101020] Universal lagfix kernel {alpha 0.1}
Diskussion i 'Galaxy S' startad av qsecofr, 20 oktober 2010.
  1. DrT
    DrT Android Medlem
    5 juli 2009
    lägg in kernel bara.
    Håller på att testa med fler språk.
  2. mickeko
    24 juni 2010
    Google Nexus 7 (2013)
    Ah han tog bort /dbdata-länkningarna.. Gör att det är lite mer intressant än innan. Ska fundera över ifall jag ska testa, kanske.. Men det känns lite poänglöst att ha finesser installerade som man inte använder.. Trots allt kör man ju bara en sorts fix åt gången.
  3. coine
    coine Kid Droid Medlem
    19 augusti 2010
    Han har uppdaterat till 0.3!!! Har precis kört lagfix "No-RFS Advanced: all partitions are ext4". Kan lugnt säga att det gick väldigt smärtfritt och telefonen känns väldigt rapp. Får se om det varar efter några dagars körning.
    Changelog
    Version 0.3
    - before the lagfix gets applied there are now multiple options to chose from:
    -- backup+restore (the original way)
    -- backup, but don't restore (this eventualy results in a factory reset)
    -- no backup (this also results in a factory reset)
    -- go to recovery mode (to debug)
    -- erase config file (to get back to the old options)
    - the screen glitch in the first screen is now gone (because the kernel got smaller)
    - jfsutils are ported to bionic (takes less space)
    - there is a new option that will do the same restore permissions run, as the init script does
    - I also added a few fixes to the CWM fix_permissions script, although I don't tested them yet (so it might brick the phone)
    - Added two more rooting option:
    -- the old one simply copyes busybox, superuser and su to the phone and adds symlinks to busybox
    -- the new ones will also remove some old toolbox commands, so if you use the shell a lot, they won't interfere. The first mode only removes the base utils, like ls,mkdir,rm or ln
    -- the second mode removes every toolbox command that has an equivalent busybox command (like mount, lsmod, rmmod, etc.)
    Remarks
    It seems that formatting dbdata as rfs only works, if you use the 512 PIT file (more exacty it only works if you have used the 512 PIT file the last time you've ticked re-partition in odin). This is probably due to the fact thet the 512 and 803 pit files reserve different space for the dbdata and for the system partition (the 803 pit file reserves 40 units less for the dbdata than the 512 pit file)
  4. trasig
    trasig Kid Droid Medlem
    3 december 2009
    funkar klockrent iaf ;p
